MH50 Problems
doorman
05-31-2007 04:56:46
My recently acquired MH50 gasser has a lot of play in the steering. When you turn the steering wheel the shaft appears to "raise up" about a half inch. Is this a bad bearing or possibly just a loose bolt on the bottom of the shaft? Also, the lift seems to pulse (vibrate) when you push down on it. Finally, what type oil goes in the trans/differential, and where is the filter located? thanks in advance doorman
