help with 135 tranny
mayt
05-30-2007 13:46:20
I have a 1970 135 MF. It has the 3 cylinder perkins gas engine. It has a 6 speed transmission 3 on the big stick and high/low on the little one. Got on it to rake hay and shifted both sticks to neutral to start it. I did not pay any attention to it at first but when I went to put the big stick in gear it would not move. up down side ways nothing. It is locked up. I put the little stick in high and the tractor backed up and that was it. No forward gears. I then took the fill plug off and could see the gears. Took a long screw driver and moved one of the gears forward. Now I have what seems to be 1st gear high. Big stick is still stuck. What todo next. Can I fix it from the plug or do I need to take the top off of the tranny. Sorry for the long post but wanted you all to know what I did. Thanks for your help in advance.
tmay
05-31-2007 08:00:58
 Re: help with 135 tranny in reply to mayt, 05-30-2007 13:46:20
Thanks Dean. I'll give that a try.
Big Dean
05-30-2007 16:00:42
You moved the gear to far forward into first gear. Move the big gear back about half as far as you moved it to get the shift forks lined up.
