mf 50 1963-perkins diesel
colin cartmill
05-28-2007 10:37:01
Hello All, after a half hour of running my front end loader becomes sluggish....?? And the fluid levels are ok. any ideas??
MF Poor
05-28-2007 14:10:12
 Re: mf 50 1963-perkins diesel in reply to colin cartmill, 05-28-2007 10:37:01
Are you running the loader off the internal hydraulic pump? Sounds like a worn pump. As fluid gets warmed up it gets thinner. Pump looses pressure. Loader gets slow.
Try changing fluid, but sounds like a pump rebuild is in the cards.
colin cartmill
05-29-2007 05:38:02
 Re: mf 50 1963-perkins diesel in reply to MF Poor, 05-28-2007 14:10:12
Hey thanks,...would you use dura-tran or Sae 90W,...how big a job is the pump rebuild??
MF Poor
05-29-2007 09:35:23
 Re: mf 50 1963-perkins diesel in reply to colin cartmill, 05-29-2007 05:38:02
DON'T use sae 90 gear lube. Hy-tran is for later model Massey's. The proper oil for those tractors is a 90 wt mineral oil. Someone will chime in with the proper "spec" for your oil. (I'm having a CRS moment, please forgive me)
Pump rebuild isn't that difficult IF you're fairly mechanically inclined. Exchange rebuilds are available through this site. Check them out for parts and complete pumps.
