MF 65 Diesel
TC26
05-27-2007 19:33:02
Need to find approximate pto horse power rating for an MF 65 diesel.
JRL
05-30-2007 19:07:18
 Re: MF 65 Diesel in reply to TC26, 05-27-2007 19:33:02
Engine: Manufacturer: Perkins Fuel: diesel Type: vertical L-head Cylinders: 4 Bore/Stroke: 3.60x5.00 inches [91 x 127 mm] Displacement: 203.5 ci [3.3 L] Compression: 17.4:1 Rated RPMs: 2000 Torque: Firing order: Transmission: Type: Forward: 6 Reverse: 1 Mechanical: MFWD: Steering: Brakes: Capacity: Fuel: 17 gal [64 L] Coolant: 10.4 qts [9 L] 3-Point Hitch: Rear Hitch Category: I Rear lift: Power Take-off (PTO): Type: live Rear speed (RPM): 540 Tires: Ag front: 6.0-16 Ag rear: 13-28 Dimensions: Weight: 4,511 lbs [2046 kg] Wheelbase: Length: Width: Height: 59 inches [149 cm] Ground clearance: Electrical: Volts: 12 Ground: Nebraska Test 659: Test Date: June 1958 Engine: gasoline PTO (max): 46.1 hp [34.4 kW] Drawbar (max): 41.6 hp [31.0 kW] Nebraska Test 745: Test Date: May 1960 Engine: diesel PTO (max): 48.6 hp [36.2 kW] Drawbar (max): 42.1 hp [31.4 kW] Nebraska Test 808: Test Date: October 1961 Engine: diesel PTO (max): 50.9 hp [38.0 kW] Drawbar (max): 43.9 hp [32.7 kW]
DavidP, South Wales
05-28-2007 00:23:45
Hi,
If you have a Perkins 192 I believe they were about 56 HP but if you have an AD4.203 then it is 58HP.
DavidP
James Jackson
05-27-2007 23:00:04
Gooday TC 26 . Go direct to Google type in " Big Dean web site " & you'll find just the nicest guy that ever was . Very knowledgeable , extremely helpful , an all round nice guy . You can also reach him @ [email protected] . I'm sure he'll have your answers & more . james in Australia .
