perkins sleaves
whit_massey
05-25-2007 05:58:21
Are AD3.152 perkins diesels dry sleaves, or are they wet sleaves?
Thank you in advance
JV3CII
05-25-2007 09:04:29
 Re: perkins sleaves in reply to whit_massey, 05-25-2007 05:58:21
I've found it worthwhile not to use liners of the type commonly sold as part of engine rebuild kits. I usually stick to either Laystall or Sheepbridge ones instead as they last much longer.
Cheers, JV.
DavidP, South Wales
05-25-2007 07:39:57
Hi,
Dry liners are fitted to the AD3.152. If you plan to change them make sure that the amount of stand-down (liner flush, to below the block face) is correct at 0 to 2 thousandths of an inch before fitting. Shims are available if needed.
DavidP
