power steering pump
Thomas Cook
05-24-2007 17:24:31
How do you tell which is the pressure line on your power steering pump? I looked at the way mine was set up, and at first i thought it was backwards because of the diagrams in the manual. (also because it wasen't working) So i switched the lines. I had the system ready to check the other day, and ended up blowing the seal at the bottom of the "cover assembly" located just above the valve assembly. Now i would like to make sure the flow is correct before i try it again. The tractor has a new after market pump purchased from the dealer. Any help would be appreciated. Thanks, Tom.
