valve kit 165
JAT
05-24-2007 06:54:58
I have 165 with a C176 engine. It runs very poorly and 3 of the 4 plugs come out covered in oil (1 drips oil when removed). I'm convinced I need a valve kit. The valve kit listed on this site doesn't mention gaskets. Do I need to order the head gasket and valve cover gasket separately?
Also, the power steering fluid is leaking into the engine. What kit/seal do I need to order for it?
Thanks
DavidP, South Wales
05-24-2007 11:14:17
 Re: valve kit 165 in reply to JAT, 05-24-2007 06:54:58
Hi, sounds like one very sick engine. Don't forget to consider the oil rings on the pistons as well.
DavidP
JAT
05-25-2007 07:01:03
 Re: valve kit 165 in reply to DavidP, South Wales, 05-24-2007 11:14:17
I was assuming that the oil was leaking down the valve guides. What are the oil control rings supposed to do exactly? Could the oil be coming up from below? Compression test (cold) was 120, 130, 145, & 140 psi (front to back).
DavidP, South Wales
05-25-2007 07:42:54
 Re: valve kit 165 in reply to JAT, 05-25-2007 07:01:03
Hi,
Your variation in compression figures whilst not way out does cause a little concern. The oil rings are there to effectively 'clean' the bore. If they are not wiping cleanly it is possible for oil to pass the top compression ring.
DavidP
JAT
05-25-2007 13:08:50
 Re: valve kit 165 in reply to DavidP, South Wales, 05-25-2007 07:42:54
So at least a in-frame rebuild is probably in order?
