MF40 Industrial Fuel Line Build-Up Question
MF40_9A197221
05-22-2007 18:17:24
Greetings! Can anyone take me through the fuel line setup from the gas tank to the Zenith carb on my MF40 with gas Perkins? What I would like to know, specifically, is if there is supposed to be a sediment bowl right out of the gas tank, fuel lift/pump somewhere, and fuel filter screwed into the Zenith 013338 carburetor. My tractor acts like it is starved for fuel, and I have none of the above in the line going from the rusty old tank to the carb. If anyone can lend some advice, I would sure appreciate it. Thanks!
tg in VA
05-26-2007 04:26:18
 Re: MF40 Industrial Fuel Line Build-Up Question in reply to MF40_9A197221 , 05-22-2007 18:17:24
If it's acting like it's starved for fuel, unscrew the entire sediment bowl assmebly from the tank. My MF20 (gas)was starving for fuel and it was trash in the tank clogging the inlet to the sediment bowl assembly. I flushed the tank and then made a sump out of galvanized pipe with an "el" to the sediment bowl assembly. Then I periodically drained the sump to remove any additional trash that accumulated, It was a very simple solution.
mn.Chuck
05-22-2007 19:42:41
Hi, From the gas tank there is a sediment bowl
assy threaded straight into the tank, a line going
down,then an inline gas filter, and a 90 degree
elbow going into the zenith carb-no lift pump on
the gas model. Good luck, Chuck
