Differential Lock Stuck
Gerry Eggart
05-18-2007 11:31:10
I have a MF 203 and both wheels are locked via the diff lock. How hard to free and best suggestions? (tried all the stuff in the manual like letting it idle, light pressure on right brake,turning right, reverse, combination of those items). The foot lever moves real smooth (to smooth if you ask me). Have seend posts where people say to remove the inspection cover ad a little WD40 on the CAM return spring. Finally, if I have to dissemble... the service manual show a speciial tool to get the CAM spring out... any suggestion if I don't have the tool?
Thanks in advance!!
-Gerry
Gerald J.
05-18-2007 19:32:19
 Re: Differential Lock Stuck in reply to Gerry Eggart, 05-18-2007 11:31:10
Had that problem on my MF-135 once. Turned out the release spring was on the pedal but the pedal was not turning the shaft. All I had to do was push the pedal down and tighten the clamp, so the spring lifting the pedal released the differential lock.
Gerald J.
