MF65 Stuck diff. lock
Jim Horrocks
05-15-2007 16:01:12
I have a Massey Ferguson 65 and while using it today the differential stuck in the locked possition. I took off the differential lock housings and could not move the shaft. Help please!
Thanks,
Jim in OR
C. Tuna
05-16-2007 17:50:13
 Re: MF65 Stuck diff. lock in reply to Jim Horrocks, 05-15-2007 16:01:12
The shaft is probably stuck in housing. Remove the brake operator next to diff lock. Check spring on diff lock shaft to see if springs looks OK and put a very small amount of oil on diff lock shaft. Too much oil will get on brakes. Sometime you need to steer the tractor each direction to get diff shaft to pop back out.
