mf 65 3pnt
ruff neck
05-14-2007 07:09:54
still not able to lift my 3pnt hitch. draft lever all the way up. position lever all the way up. the pto turns when engaged. can't seem to locate any valves or levers under the seat. what am i missing? just bought the tractor and the hitch was up, now it hanges inches above the ground. help
Massey 35x
05-21-2007 14:28:05
 Re: mf 65 3pnt in reply to ruff neck, 05-14-2007 07:09:54
Its an airlock by the sounds of it i had the same problem, took my neighbouring mechanic 30 seconds with a spanner to fix. I dont remember how but dont worry its pretty simple if u know any local mechanics they can do it no problem
DavidP, South Wales
05-14-2007 13:16:48
Hi,
At the front right hand side of the hydraulic cover is there a valve of any sort fitted? The original plate was about 4" x 3" and was held by two bolts.
Please let us know what you have fitted.
DavidP
