23C diesel oil pressure
greg js
05-14-2007 06:13:06
Tractor is TO 35 with a 23C Diesel. The longer i run this tractor the lower the oil pressure gets. Any thoughts as to why? I am thinking the oil pump may need rebuilt?
Thanks in advance
Gerald Eggart
05-14-2007 09:16:45
 Re: 23C diesel oil pressure in reply to greg js, 05-14-2007 06:13:06
I have a MF203 with a perkins 3 Cycl diesel. Same issue. OP great until after about an hour... then almost zero.
Found that my main bearing was worn out. Also, from reading many posts here, this seems to be the common issue when you OP dips real low. Mine's going to be back from the rebuilder this week. Should be good to go for the next 30 years!
If you in MI, I can recommend someone, fairly cheap as far as engine rebuild go.
Good luck.
