Best PS lube for 65
NEsota
05-11-2007 12:51:54
It pains me to post for this info but.... mine is a Barnes pump on a gasser. Is DEXRON III/ MERCON suitable to use and what would be the best fluid to use? Yes, I have owners manual but it is out of State and maybe out of date.
Aaron Ford
05-13-2007 17:00:14
 Re: Best PS lube for 65 in reply to NEsota, 05-11-2007 12:51:54
Oops, thanks for the straighten around there. I better go drain something... Not saying what.
Cheers,
Aaron
NEsota
05-12-2007 13:02:54
Thanks Dean, will treat that as gospel.
Big DEan
05-12-2007 08:40:52
A service bulletin we received from Massey Ferguson sometime in the late 1970s when the Dextron oils was first introduced in place of the old type A transmission fluid said to replace it with the M1129A or M1127 used in the transmission both of those oils were replaced Permatrans 3 it when on to say the seals that Massey used was not compatible with Dextron oils
NEsota
05-12-2007 05:01:54
Thanks guys. My attempted search of the archives was not successful. I meant to say service manual rather than owners.
Aaron Ford
05-11-2007 17:49:20
I believe the manual calls for Type A. I believe the modern equivalent is Dextron III. HTH
Aaron
MF#1
05-11-2007 14:02:24
Always go with what the manual says. I never use auto trany fluid, use Perma-Tran hydraulic fluid unless otherwise noted.
