30B hyd/trans oil same sys?
suptscottyb
05-11-2007 05:43:23
Is the same oil fill for hydraulics used by the trans. I see another large fill hole left of the gear selectors. The tractor is industrial with 4 gears and shuttle shift.
suptscottyb
05-11-2007 17:03:26
 Re: 30B hyd/trans oil same sys? in reply to suptscottyb, 05-11-2007 05:43:23
Thanks for that info. I've been to your site. I enjoyed it and plan to go back. Do you know what it takes to service the power steering pump?
Big Dean
05-11-2007 10:43:25
The MF30B has a common reservoir for the transmission hydraulics and the rear end it is check with the dipstick on the right side of the rear center housing above the step plate they all fill through the hole for the big plug just left of the shift the oil used is MF Permatran 3 or one of the universal Trans/Hyd oil sold at about any place that sells oil.
