MF power stearing pump
37 chief
05-08-2007 21:36:54
Is there a way to check the pressure on the stearing pump output for my MF 231 with the 3 cyl diesel? What should the pressure be? It is geting hard to stear. Stan
Big Dean
05-10-2007 13:14:57
 Re: MF power stearing pump in reply to 37 chief, 05-08-2007 21:36:54
There is a picture showing how to connect a gauge to check the power steering pressure at this link hope it helps
apm
05-10-2007 04:31:44
Stan,
As you find out about your powersteering email me at [email protected] I just bought a 231 same tractor as yours and trying to work out some steering issues. Im going to drain my system because some one had put wrong fluid in pump, my wheels wobble back and forth at shocks as I mow, and I have air in my system. they say the system can have the same special trans oil that's in the transmission or the tractor.
RICH N.Y.
05-09-2007 13:22:42
There be a filter in that thar pump. Probably never changed. I have a MF 30E, same problem. Bought the filter from Massey for less than ten bucks. Gonna try that first, then the new pump: $250-350.00. Good luck-Buy the manuals.
