30B spin on oil filter
suptscottyb
05-08-2007 20:41:42
Okay. I"ve found that the spin on head I have is a PK 33764251. The filter is A-2654408.
I am looking for a x-reference # that I can get at Napa, etc. The Wix reference didn"t find anything. Any help is appreciated.
Bob
05-08-2007 21:14:13
 Re: 30B spin on oil filter in reply to suptscottyb, 05-08-2007 20:41:42
Perkins Part # 2654408 = WIX # 51460.
By application, WIX oil filter for Massey 30B/with Perkins engine = WIX # 51460.
Generally for a NAPA number, you drop the first #, making it a 1460.
William Bos
05-10-2007 17:23:52
 Re: 30B spin on oil filter in reply to Bob, 05-08-2007 21:14:13
Oil Filters
AC PF 2205
MF 1447082M1
Don't ever use Fram. Your tractor does not deserve that!!
Good Luck.
suptscottyb
05-10-2007 18:42:57
 Re: 30B spin on oil filter in reply to William Bos, 05-10-2007 17:23:52
Thanxs for the filter #s and advice. What's the story on Fram filters?
scott boersma
05-10-2007 06:51:50
Thank you, Bob. Will change that oil today.
I saw another discussion about a power steering filter. Do you know where it is and how to change it. My tractor steers hard at low speed / rpm .
Thanks again.
suptscottyb
05-10-2007 18:36:28
 Re: 30B spin on oil filter in reply to scott boersma, 05-10-2007 06:51:50
It's a 1979 industial 2 wd skiploader. Powered by a Perkins 3 cyl. The pump looks gear driven, mounted behind the timing cover assembly.
I found a massey tag on it with #14172.
Made by John S Barns Corp. Rockford, Ill.
The housing does have a seies of small nuts all the way around it - for service?
Would a new seal on the two halves be needed if diassembled for service?
Also, one of the steering rams leaks. It was low on fluid and hard to steer when I got. It greatly improved with fluid and I have been feeding the leak for some time with no change.
Bob
05-10-2007 08:18:59
I'm not familiar with your particular tractor.
However, if it has a belt-driven PS pump, the filter MAY be inside the reservoir that surrounds the pump, requiring disassembly to replace.
Is that how your's is set up?
