PTO low press light Super 90
uedlose
05-06-2007 15:15:44
low press. for PTO light came on. on my Super 90 diesel put a new switch on it and no luck pulled the pump out of it and dont see a thing wrong with it cleaned all the filters still no go. I really dont want to hurt the old girl she runs like a top. anyone know the line press. for the PTO? every thing works fine also I just use it for mowing and that is about it. Thanks
brianriver
05-07-2007 14:31:30
 Re: PTO low press light Super 90 in reply to uedlose, 05-06-2007 15:15:44
Been 25 years since I worked on one so my mind may be a bit fuzzy. The PTO should have somewhere near 200-250 pounds of pressure. I believe there is a dump vale inside the clutch housing to release pressure to the live PTO when you push the transmission foot lever all the way down. It is possible this valve is stuck out from very little use and causing the low pressure light to come on. You may be able to pull the inspcetion plate off the bottom the the clutch housing and see if that is the case. If the valve does not go in after fully depressing the foot clucth, you may be able to 'persuade' it back some, or else split at clutch. Obivously, run too long on low pressure and PTO cluctch may need rebuilding and you split that behind the tranny for rebuild.
