2000 Series 3 point
05-04-2007 08:35:16
I did get the wiper seal and o-rings changed out on that 2745 last week. In case anyone else needs to do the same job, here's the routine. The bolt on the top of the lift cylinder is designed in a cone shape. A little heat and it comes right out. The lower pin is assembled with a locking pin with an allen head. Remove the allen bolt and apply a little heat to the housing. The second pin comes out toward the rear wheel. Once you remove the hydraulic line, you will need to remove the fitting from the cylinder. Inside the hole is a pin that needs to be removed. From there, the assembly seperates and you can see your parts for replacement. Overall job time was 2 hours.
