MF 2135
Jack
09-25-2000 04:33:21
Greetings All
I've located a very used Massey Ferguson 2135 tractor, with loader, that I'm considering purchasing. This thing starts right up, but smokes like the dickens (4-cyl gas engine). The current owner says the engine was rebuilt and the rings on one cylinder didn't "seat". Does anyone know the horsepower of this beast and ball park cost on an engine rebuild?
Thanks
Tyler(WA)
09-29-2000 08:23:43
 Re: MF 2135 in reply to Jack, 09-25-2000 04:33:21
I have one o' those.
If it's the Continental Z-134 engine, it has about 37 hp (I think). These engines are good runners and rebuild parts are available (even through NAPA). Check the resources listed on the left side of this site page and you can price complete rebuild kits.
Check compression on each cylinder to confirm the problem is with only one. Run the tractor with that plug removed and the smoke should stop.
These engines don't like to run hot (ever) and often can crack a block between cylinders. Compression testing should identify which cylinder is having problems but only a good inspection with the head off will tell for sure.
If your seller is straight, make a deal to pull the head and make a purchase dependant on a satisfactory inspection. You won't be out more than some elbow grease and time but you can save yourself from buying more than you bargained for.
Jack
09-29-2000 17:13:22
 Re: Re: MF 2135 in reply to Tyler(WA), 09-29-2000 08:23:43
Many thanks Tyler, you gave me some great info that will help me to make a better decision.
