where can i find MF 35 wheel centers?
gottractor1
05-03-2007 10:51:12
I just bought a MF 35, my issue is that i have the tires filled with fluid, teh heavy, industrial type weighted wheel centers, and additional wheel weights mounted on the outside of the wheel. My tractor will spend most of it"s life mowing, so this is more than just a little overkill. Where can i find teh standard wheel centers? Used wheels would be just fine, this is a low budget operation. So far my search has not been successful. I live in wester south dakota if that helps.
Dean
05-04-2007 03:53:28
 Re: where can i find MF 35 wheel centers? in reply to gottractor1, 05-03-2007 10:51:12
Gott:
Any Ferguson or Ford wheel discs from the 1950s or early 1960s will work on your 35.
If you want the power adjust centers, I believe that the much more common AC power adjust centers/rims will bolt right on but you should verify this before buying. AC wheels from WDs are pretty much a dime a dozen.
Dean
gottractor1
05-04-2007 07:56:24
 Re: where can i find MF 35 wheel centers? in reply to Dean, 05-04-2007 03:53:28
Thanks Dean. good to know the ford wheels will fit, they seem to be much more common around here. Good to know that the AC wheels might fit as well. That gives me lots of options.
