1959 Massey Ferguson TO-35
Trent Baldwin
04-30-2007 12:08:59
I have a 1959 Massey Ferguson TO-35 Gas tractor. How can I tell if it is a GAS SPECIAL or a GAS DELUXE? What was the difference between the two?
Thanks,
Trent
mark from the fort
05-03-2007 05:30:17
 Re: 1959 Massey Ferguson TO-35 in reply to Trent Baldwin, 04-30-2007 12:08:59
Main difference is the two stage clutch. put your p.t.o selector into "engine" speed and let upon clutch-should be spinning. Now,place tractor into low 1st gear-start moving forward. Push clutch 1/2 way down, tractor will STOP moving, BUT p.t.o. should still be spinning. Push clutch rest of way down, NOW p.t.o. should also stop--IF SO, you have two-stage clutch. If clutch stops both tractor and p.t.o. only, then single clutch. Others signs of DELUXE,(but not always true) is larger pan seat with cushion on bottom and back, 4 guages on you dash in stead of 2. Most obvious is large hole in middle for trachtometer.-the reason I said "not always true" is many parts gets swapped back and forth over the years.
Main thing you want is the 2 stage clutch. Mark
CENTAUR
04-30-2007 16:19:04
Click on (return to forum)and go back a few days and you will find a very good detailed answer.CENTAUR
CENTAUR
04-30-2007 16:23:41
 Re: 1959 Massey Ferguson TO-35 in reply to CENTAUR, 04-30-2007 16:19:04
Sorry! Go to FERGUSON. CENTAUR
