power steering MF 135
Donald In Ky
04-29-2007 18:30:47
The steering is leaking at the top where the shaft goes to the steering wheel. any ideal what i need to fix the problem. Thanks Donald in ky
Les McClelland
05-13-2007 19:23:08
 Re: power steering MF 135 in reply to Donald In Ky, 04-29-2007 18:30:47
Mine leaked as well when I got it two years ago. Remove the instruments and the wheel and the flanged housing from the top of the gear. You do not need to remove the gear and cylinder. The seal is easily replaced with proper tools. Take the flange and new seal to a machine shop and they will replace it for you if you aren"t familiar with the practice. It has worked well ever since. It took about 2 to 3 hours if I remember right.
Gerald J.
04-29-2007 20:37:04
There is a seal up there. I cracked the column housing punching mine out with a long rod, You need to be sure of pushing only on the seal. My parts book says its MF numbeer 1 751 701 M1. Looks like it is somewhere towards the bottom of the steering shaft housing which you will have to take off the steering valve (after you remove the steering wheel and the dash of the tractor) to reach it. As I recall the seal wasn't hard to find from MF, but it took a machine shop to fix the housing flange that I broke. Its worked fine for me ever since.
The valve is shown disassembled in the parts book and in the I&T manual.
Gerald J.
