TO- 35 Stuck in #3 rd Gear
David Thames
04-28-2007 11:19:07
While operating my tractor today it got stuck in third gear. I have tried rockng the machine and trying to shift at the same time with no results. High and low range work fine. Need some help!!!!
Thanks
DT
mn.Chuck
04-28-2007 16:46:29
 Re: TO- 35 Stuck in #3 rd Gear in reply to David Thames, 04-28-2007 11:19:07
Hi David, Common and not serious. Remove Oil fill
plug by trans levers. Then with a small bar or
huge screwdriver,center the shift forks on the
the rails. Now someone should post that remembers
exactly which way to move(I forget lots) but you
can move it and try your levers. You won't have a
problem. Chuck
David Thames
04-28-2007 17:22:08
 Re: TO- 35 Stuck in #3 rd Gear in reply to mn.Chuck, 04-28-2007 16:46:29
Thanks Chuck-- Would not have ever figured it out myself.It is back in workng order again.Pull the fork towads the rear of the tractor.
Thanks Again
DT in Mississippi
C. T. in Oklahoma
04-29-2007 07:31:59
 Re: TO- 35 Stuck in #3 rd Gear in reply to David Thames, 04-28-2007 17:22:08
David, Big Dean will always tell you to apply downward pressure on the shifter when changing gears. That should prevent it from happening. C. T.
