MF model 50
J.Emery
04-28-2007 05:07:13
What can you guys tell me about a MF model 50?
MF Poor
04-28-2007 07:19:43
 Re: MF model 50 in reply to J.Emery, 04-28-2007 05:07:13
First came the Massey Harris 50 and Ferguson F-40. The MF 50 followed right after merger of the 2 companies was completed. They "matured" into the MF150 when the "DX" series was introduced. From what I can gather, all these models were for U.S. market only when new. Some have found their way around the world nowdays.
The 40/50/150 series took the drivetrain of the 35/135 and bulked up the front end. Steering column and power steering is the same as the bigger MF65. Same goes for the heavier (and more ground clearance) front axle of the 65. With the heavier steering bolster, approx. 9" was added to the over-all wheelbase. The longer front end made room for a bigger radiator, as well as allowing the 65's oil bath air cleaner on the 50 (and dry element filter from the 165 was used on the 150) Sheet metal was much the same as the 65. That allowed a bigger fuel tank to be fitted. (20 gal. in place of 12)
All those changes added approx. 400 lbs on the front end. That coupled with the longer chassis made the 40/50/150 much more stable with a load on the hitch. The 40/50/150 is in essense, a "row crop" version of the classic 35/135.
The 40/50/150 was also built in a "high arch" configuration. (38" rear wheels, higher clearance front axle) High arch models were also available with single or dual wheel narrow front ends.
The heavier steering bolster had mounting points for a mid-mount cultivator as well as better mounting for front end loaders.
I've read a couple accounts that stated the 40/50 was the last tractor Harry Ferguson had a "hands on" part in the development. Seems Harry didn't think his company needed to go for the marketing of bigger tractors.
Yes I am crazy about these tractors! I've got a restored 150 that I bought new in 1971, am starting to work on an F-40 my father bought new in 1956, and there's an MF50 out behind the shop waiting its turn. That one was bought new by my uncle in 1957. Someday I hope to include a MH50 to the set.
When the 200 series was released, there was no direct "replacement" for the 150. The 245 had a straight axle (as opposed to the 135/230 swept back axle) but wasn't the "same".
Aaron Ford
04-28-2007 06:51:01
Built from 1957-1964, initially called MH50 and F-40, basically a stretched TO35. Shares many parts with the TO35, MF35, MF135, MF150, and some from the MF65 and 165.
Around 30 HP.
Starting price around $3,000 and not uncommon to se one going for $5,000 or more.
Parts are abundantly available and cheap.
The Perkins is the engine to have, but there is nothing wrong with the Continental. Both engines are strong.
Anything else?
Aaron
JEmery
05-03-2007 04:14:30
 Re: MF model 50 in reply to Aaron Ford, 04-28-2007 06:51:01
Does the model 50 have power steering?
Lou
04-28-2007 06:30:31
I have a 50 3 cyl perkins diesel with a loader and its a great tractor. The gasers are ok , but not as ok. The 50 is very similar to a 35, Im sure many parts are interchangable. A lot of tractoir for the money.
