MF135 Fuel Filter Problems
James Russ
09-22-2000 17:50:59
I have replaced the fuel filter on this tractor before and didn't have this problem. I tried to Air-Bleed the system and can't seem to get any air out. No matter how long I pump the manual pump,no air bubbles or fuel. Any Ideas.
Thyge
09-26-2000 11:17:54
 Re: MF135 Fuel Filter Problems in reply to James Russ, 09-22-2000 17:50:59
I had a similar problem on my 35X. It was a clogged fuel line and a rusty spring in one of the valves in the fuel pump. Do you have any motion in the sediment glass when you are pumping? If you have fierce motion in the glass, you might have a leaky inlet valve.
-may this be of use...
