Massey Ferguson 135
Jimmythec
04-25-2007 20:19:46
Any thoughts on what a MF 135 Diesel with a factory loader and an OK back blade might be worth? The tires are not much good and it needs an alternator. The body is a little beat but the loader and the engine seem great. It has the Hyd pump out front. The Hyd hoses are pretty checked and it looks like the wiring could use some work. Also the tach and hour meter are broken as in smashed. It seems to run and drive fine. Thanks, Jim
newbeerich
05-07-2007 07:23:19
 Re: Massey Ferguson 135 in reply to Jimmythec, 04-25-2007 20:19:46
I purchased a MF 135 last fall in good running order w/ 40% rear tires, and new paint with a 5' woods mower and a new tractor supply one bottom 3 pt plow for $5,000.
I wanted a loader but couldn't locate one yet. I am pleased with the tractor. It runs well, and always starts even in mid-winter.
Jerry CPP (WA)
04-26-2007 09:31:32
I don't know what the value may be where you are, but I paid $3000 4-5 years ago for a MF-135 Perkins gas with front blade, 20% tires, leaking oil and brakes poor. I'd do it again - I put new tires on, overhauled and painted it, and wouldn't trade it for any other tractor. I figure right now it's worth about $6000, which is what one in top condition goes for here in Central Washington State.
Jimmythec
04-26-2007 15:57:58
 Re: Massey Ferguson 135 in reply to Jerry CPP (WA), 04-26-2007 09:31:32
Thanks for the info Jerry. I am in south central Washington State. They want $4800 for it but it seems a little high to me considering that it has not been maintained very vell at all. I think it would be a good tractor with some money put into it and you guy"s on this site sure seem to like them.
Jerry CPP (WA)
04-27-2007 05:06:21
 Re: Massey Ferguson 135 in reply to Jimmythec, 04-26-2007 15:57:58
Jimmythec - if you're that close, check out the huge farm equipment auction at Heaverlo in Yakima, coming Saturday May 12, 2007. Check them out on the net. They should have a bunch of tractors available, maybe even one you want, but I'll say a good 135 is worth the wait. I'm near Wenatchee, and will be coming down to Yakima just to watch - one never knows what one can't live without until one sees it.
jimmythec
04-27-2007 06:12:34
 Re: Massey Ferguson 135 in reply to Jerry CPP (WA), 04-27-2007 05:06:21
Thanks Jerry! I did not know about that auction and will probably go. I am only about 65 miles away. Thanks for the heads up! Jim
Aaron Ford
04-26-2007 20:21:50
They are about 800-1000 high. Make a nice project, but the initial price would definitely be a setback. Wave 3K in cash under his nose. Might work. Good Luck,
Aaron
VTE
04-29-2007 02:47:22
 Re: Massey Ferguson 135 in reply to Aaron Ford, 04-26-2007 20:21:50
In the UK a tractor requiring some work like you're describing would make �1,500 max (about $3,000) so I think Aaron's about right. Good original (but not restored) examples in the UK make up to �3,500.
Steve, vintagetractorengineer.com
