44 clutch to 44-6
mm-g706
04-24-2007 19:17:30
I'm having problems with the clutch in my 44-6 and was wondering if all the clutch part are the same a regualr 44. so the question is Did 44-6 and 44 use the same Clutch disk,pressure plate, throw out bearing assembly. thanks
mm-g706
04-25-2007 10:12:57
 Re: 44 clutch to 44-6 in reply to mm-g706, 04-24-2007 19:17:30
Chuck thanks for all the information
mn.Chuck
04-25-2007 10:01:22
I did some more checking. The clutch plate and
also the pilot will fit from 44 to 44-6. Good
luck. Chuck
mn.Chuck
04-24-2007 20:41:06
Hi, I have very good parts info on these. The
pressure plate, throw-out brg assy and the clutch
lining are the same, but somehow the complete
lined disk has a different part no. The shaft is
a diff p/n and wonder if it has a smaller spline
on the 44-6. I'll try to look some more tomorrow.
Chuck
msb
04-24-2007 20:17:31
I think so and even a 61 Ford truck used the same disk, I have been told.
