555 bleed
Gene Zacharias
04-24-2007 06:30:20
I got a 555 massey Haris Deisel from my grandpa. I have trouble that when out of fuel it don't run. HA ha. But seriously. What is the best way to bleed the system out without having to pull it 2 miles to get it running. Is there any way of putting a priming pump on the system? I even thought of putting on an electric fuel pump just to help out the gravity feed.
mn.Chuck
04-24-2007 16:23:05
 Re: 555 bleed in reply to Gene Zacharias, 04-24-2007 06:30:20
Gene, It should not be necessary to add anything.
If you prime it properly it will run. Be sure fuel
in the tank!! Then follow "priming the fuel system" in your manual. If your batteries are low
boost before starting. Never operate that starter
over 20 seconds w/o a cool down. Good luck Gene,
Chuck
