MF35 clutch
garvas
04-23-2007 07:45:02
When adjusting a two stage cluth on a gas MF35 and the manual calls for .088 clearance does it mean between the adjusting screws and where the strike the clutch? Or is measurement between the clutch face? I can't see how you could hardly get a feeler guage up in there but then maybe make a gauge. My PTO won't engage without grinding gears. Works grest other than that.
DavidP, South Wales
04-23-2007 08:53:56
 Re: MF35 clutch in reply to garvas, 04-23-2007 07:45:02
HEllo,
Yes, that is the clearance between the adjusting bolt head and the point where it meets the PTO pressure plate. Don't forget to check the clearance between the footbar and the clutch pedal. You should have about 3/8". When you press the pedal fully make sure that you cannot hear or feel the release levers hitting the rivets on the PTO plate. If you can, increase the gap a little.
DavidP
Jack in NB
04-23-2007 14:34:44
 Re: MF35 clutch in reply to DavidP, South Wales, 04-23-2007 08:53:56
We've had to decrease the clearance on ours to .055 - .065 to eliminate the grinding.
I think Big Dean says something along the same lines.
We haven't had a problem with rivet contact at that setting, but it's wise to listen for it anyway!
