MF 65 gas
hdlong
04-23-2007 04:04:49
How to change or rebuild oil pump help please!
Oil pressure has dropped from approx.25# pressure to about 10# changed oil and filter put in 40wt. didn't help.Could someone out line the details of changeing out or rebuilding the oil pump. 1962 MF65 gas Thanks
Aaron Ford
04-23-2007 19:31:27
 Re: MF 65 gas in reply to hdlong, 04-23-2007 04:04:49
You can buy a pump rebuild kit on this site.
Drop pan, unscrew compression nut and small bolt holding pickup. Cut safety wire and take the two bolts out of the front main bearing, remove pump. Take a large fresh screwdriver and take the 4 cap screws out. One side will drop into your hand, the drive gear will need pressed off and when rebuilding, pressed back on. Reassemble. Mains are torqued to 85-95 foot pounds. Reinstall safety wire, pickup, and pan.
third party image
Hope this helps,
Aaron
