power steering pump
jims180
04-20-2007 18:52:02
Hello to everyone,
Does anyone know if the power steering pump on the 1967 MF 180 perkins 236 can be rebuilt? If so where might I find a rebuild kit? It seems to be leaking into the crankcase...maybe just a seal needs to be replaced. As long as I keep fluid in it, it works just fine.
Thanks
Jim
jims180
04-22-2007 05:37:20
 Re: power steering pump in reply to jims180, 04-20-2007 18:52:02
Thank you!!!
David and Chuck,I am glad to here it is just a seal gone hard,pump replacement seems a little extreme at 300.00 US dollars or more plus shipping. I will order the seals this week and fit them.
Thanks again, Jim
DavidP, South Wales
04-22-2007 04:59:29
Hello, Yes, the seal is normally the source of the problem when they go hard.
You should have either a 'Plessey' or 'Air Equipment' pump fitted.
The seal kit number for the Plessey is 1810 417M91 for pump number 897146M92&M93 or 1810 618M92 for pump number 897146M94
For Air Equipment pump 3774 649M91 the kit is 1635 948M92
Make sure you fit the pressure seal the correct way.
DavidP, South Wales
mn.Chuck
04-21-2007 09:05:48
Hi Jim, The seal is all that is wrong. Some P.S.
pump seals can be drilled and pulled right out and
others must go thru the casting to the inside-not
sure which yours is-anyway not a big job. Serial
no. is necessary for the correct seal(or kit)Kit
may be good while you are at it. You need to spec
the serial no. , also the 180 had gas or diesel
(plus Cont.on earliest) in that same ci Perkins
engine so need to specify that. Good luck, Chuck.
