Crankcase Blowby
Tim Lockey
04-19-2007 14:04:12
In an earlier post I described how my 240 went from showing nearly no blowby thru the crankcase vent, to loads of smoke in a really short time. After removing the head, I found a blown head gasket between two cylinders. My question is, is this the cause of my problems, or should i dissasemble further? How would the oil/vapor/smoke get to the breather tube fromthe cylinders? Through an open valve and past the guides? Wondering what to do next.
Don-Wi
04-19-2007 22:37:32
 Re: Crankcase Blowby in reply to Tim Lockey, 04-19-2007 14:04:12
I'm assuming this is after an overhaul...
Did you re-tourque the headbolts after getting it warm the first time? If not, the gasket SHOULD be your only problem. After installing a new gasket and letting it run till it's warm, re-tourque the head bolts or you'll blow another gasket.
Donovan from Wisconsin
