MF35
Ignition upgrade?
Daryl
09-21-2000 06:12:48
My recent "No power" question seems to have been solved via yet another(!) new condenser. It wasn't fuel related as some suggested, although I now have that system as clean as a whistle.
But that, and the information on switching to an alternator from the original generator, got me wondering. Has anyone ever tried getting rid of the ignition points in favour of a more modern electronic ignition system? Has anyone found anything to work?
garvas
09-23-2000 16:12:05
 Re: MF35 - Ignition upgrade? in reply to Daryl, 09-21-2000 06:12:48
Try this site.
www.pertronix.com
I haven't tried one but I understand they make a good product.
Tyler(WA)
09-21-2000 07:54:18
Not only is it a good idea but you'll wonder why you ever put points in your tractor in the first place. Try this link.
Rex
09-23-2000 21:29:13
 Re: Re: MF35 - Ignition upgrade? in reply to Tyler(WA), 09-21-2000 07:54:18
If you have upgraded the charging system, check that it is not over charging as that is hard on points and condenser.
Put a volt meter across the battery terminals when the engine is running at medium revs, should be between 13.8 to 14.2 volts.
May well be ok, but worth checking. The electronic replacement for points is a wonderful thing too if you do make the change.
Good luck, rex
