Big Dean MF 240 p.s. leak
djw
04-18-2007 05:06:19
I v'e got a MF 240 that for the past couple months when shut down, leaks PS fuid from the top of the steering column. No leaks when running. After removing the filler cap from the resevior, sounds like pressure escaping. Is there of vent that is plugged that would cause this? Any other possibilitys? Thanks in advance Dave
djw
04-18-2007 18:00:12
 Re: Big Dean MF 240 p.s. leak in reply to djw, 04-18-2007 05:06:19
Thanks Big Dean, You are right the column itself is not leaking , but the valve beside it , I will keep you posted on my progress Thanks Dave
Big Dean
04-18-2007 12:40:11
Unless they changed the steering system on the MF240 since I retired in 1995 there is no power steering fluid in the steering column it's self. There is a selector valve on the upper right side of the steering column I have seen them leak there if this is where yours is leaking then you need to replace the O-rings in that valve.
