massey 165 deisel ,oil cooler ?
Joe Jackson
04-17-2007 16:53:41
Trying to repair the front of my new project, where is the oil cooler supposed to be attached ?,it was just wired to what was left of the grill.
Joe J
04-18-2007 05:12:40
 Re: massey 165 deisel ,oil cooler ? in reply to Joe Jackson, 04-17-2007 16:53:41
Thank you,looks like I need to purchase a grill .probably why I couldnt figure out where it was mounted.I need to tear the hood assembly off and tighten everything up anyway.steering wheel moves so much that it increases or decreases the RPMs when turning .Thanks again
DavidP, South Wales
04-19-2007 00:02:47
 Re: massey 165 deisel ,oil cooler ? in reply to Joe J, 04-18-2007 05:12:40
Hi Joe,
If you have power steering fitted please get in touch before you make any adjustments.
David
Joe J
04-19-2007 16:38:46
 Re: massey 165 deisel ,oil cooler ? in reply to DavidP, South Wales, 04-19-2007 00:02:47
It has power assist steering and seems to work well at this time other than the excess movement of the assembly that the guages and throttle attach to.thanks
DavidP, South Wales
04-18-2007 03:28:56
Hi Joe,
At the bottom of the oil cooler you should see two forks in the end plate. These locate on pegs just inside the front door at the bottom of the grill. AT the top of the cooler are two horizontal slots about 3 inches apart. These locate on a bracket with two thumb nuts at the top and just inside the grill door. Sounds like you may be missing the brackets.
DavidP
