replace belt on massey 40
tubeless cactus
04-16-2007 19:43:28
i just bought a massey 40 backhole its the first ever tractor ive owned it broke a belt it has a diesel it has a shaft coming from the crank pulley going through a large bar that the front wheels attch to and all the way through to the front a the machine to what looks like a pump i need to knw the steps to brake down the machine to replace the belt this looks like its going to be a big job any help i could get would be great tubeless cactus
Big Dean
04-17-2007 04:11:18
 Re: replace belt on massey 40 in reply to tubeless cactus, 04-16-2007 19:43:28
There are a couple of ways to change the fan belt on the tractor with a front crankshaft driven pump you first remove the pump [1] You need an old pump to rob a shaft from. You then weld a socket to that the old pump shaft. If you have a regular transmission put both shift levers in high set the brakes turn the shaft clockwise the shaft has counterclockwise threads on it. The shaft can get very tight and if you have access to an impact wrench you will probably need it to bust the shaft loose If you have an industrial with the Instant Reverse (hydraulic shuttle) transmission you will have to use an impact for sure on them. [2] Without that homemade tool you remove the pump so the shaft can move forward. You unbolt the adapter plate from the crankshaft pulley. Some tractors there will be enough room you can slide the belt between the pulley and the adapter plate but most there will not be enough room for belt to slide through. If you don't have room to get the belt out you will have to put a jack under the oil pan to hold the weight (just take the weight do not raise the tractor) Loosen the six bolts 4 or 5 rounds the bolts that hold the front axle support to the engine so the front support can be pried forward enough to slide the belt through. You may also have to loosen the bolts that hold the front of the loader to the tractor.
tubeless cactus
04-18-2007 19:14:47
 Re: replace belt on massey 40 in reply to Big Dean, 04-17-2007 04:11:18
thanks Big Dean for the help you were rite on the mark made it very simple im up and running again
