35 Charging
Croitear
04-16-2007 05:07:01
The battery on my 35 was flat the other day but managed to bump start it. The ammeter shows that it is charging well when it first starts up, but after 10 mins or so the guage returns to the centre. I haven't put a meter across the battery yet but would it be normal for it to stop charging. Could that be because the battery is full or because the battery is knackered. Thanks.
PS its a dynamo thats on the tractor
Dean
04-16-2007 15:19:43
 Re: 35 Charging in reply to Croitear, 04-16-2007 05:07:01
It sounds to me like your charging system is functioning properly.
Either your battery is failing or you have a parasitic load that is draining the battery when the tractor is not running.
You can check the battery by load testing it and you can check for a parasitic load load by removing one of the battery cables and inserting an ampmeter between the battery post and the cable with the engine and lights, etc. turned off.
Dean
croitear
04-17-2007 07:47:56
 Re: 35 Charging in reply to Dean, 04-16-2007 15:19:43
Thanks Dean. I put a meter across the battery last night and yes it is charging fine. That's about the sum of my electrical skills so will check tonight whether something is draining the battery in the way you suggest.
