MF65 w/6 cyl. gas engine - OIL PRESSURE??
rob trist
04-14-2007 10:17:55
I have a MF65 tractor with a 6 cylinder gas engine and was wondering what the oil pressure should be reading. Mine reads right around 20 or 22 and the tractor starts right up and runs great.
Thanks!!
rob
MF#1
04-14-2007 12:33:17
 Re: MF65 w/6 cyl. gas engine - OIL PRESSURE?? in reply to rob trist, 04-14-2007 10:17:55
Rob, I wouldn"t do a thing to it but put it in a museum. I"ve never seen a 6 cyl gas in a MF 65. Doesn"t mean it doesn"t exist, just really rare. 20-22 doesn"t sound too bad if it stil runs good, keep an eye on it if you"re working it hard.
rob trist
04-14-2007 13:30:43
 Re: MF65 w/6 cyl. gas engine - OIL PRESSURE?? in reply to MF#1, 04-14-2007 12:33:17
Oops ..... .....that would be a 4 cyl..... .duh...I actually I'm alive and well..... ....lol.....
MF#1
04-14-2007 18:38:20
 Re: MF65 w/6 cyl. gas engine - OIL PRESSURE?? in reply to rob trist, 04-14-2007 13:30:43
Shoot, I was hoping for a bona-fide rarity;-) Don"t know what the book says but anything above 20 or so should be ok. I might try a heavier weight oil to see if it gets better. At idle, warmed up, need probably 15 minimum, so keep an eye on it. It"s a tough tractor but low/no oil pressure will kill it quick. Might invest in an owners or repair manual for the actual numbers.
rob trist
04-18-2007 17:17:07
 Re: MF65 w/6 cyl. gas engine - OIL PRESSURE?? in reply to MF#1, 04-14-2007 18:38:20
Sorry bout the rarity situation....anyhow at idle it has 20 but it mostlyl just stays there even at higher rpms..... ..... ..what heaveir weight oil should I try ..... I believe I put 10W30 in it which is what the manual called for. Any advice on any other things that could help raise it would be appreciated.
Thanks!!
rob
