no oil pressure-HELP!
spitz
04-13-2007 17:15:12
Just got my engine in and started but no oil pressure. The pump has been rebuilt and so has the engine. The pump will get oil to the relief valve but still no pressure at the guage or lines to the guage. Does the oil go to the filter then to the engine or engine and then filter to pan? This is on a pacer-continental y91. Thanks for your help.
Gerald J.
04-13-2007 19:54:14
 Re: no oil pressure-HELP! in reply to spitz, 04-13-2007 17:15:12
I have a Y-91 on an Onan generator. The oil filter is a bypass filter. There is a large hex plug on the side of the block with a spring loaded pressure regulator piston valve. I shimmed it slightly once to raise the pressure. Be sure the spring and piston isn't stuck open. You may have to check to be sure the oil holes in the cam shaft bearings align with the oil holes in the block to get oil to flow to all the engine.
I had to replace many of the oil line fittings because vibration had worn them sloppy.
Gerald J.
