steering box fluid on 165?
Frank Thomas
04-08-2007 09:31:30
I have a 1972 165MF. The box where the steering colum connects to there is a plug on the left hand side and a adjuster nut on the opposite side. Is there suppose to be oil in here. Right now there is none and when I turn the steering wheel it turns about a half revolution in each direction and the steering shaft and wheel moves up and down about a inch up and down. Is this okay also.
Aaron Ford
04-08-2007 10:56:38
 Re: steering box fluid on 165? in reply to Frank Thomas, 04-08-2007 09:31:30
Oil yes, play, no. Takes gear oil. Ball bearings on top and bottom. Pull the plate and inspect for damage.
Should look like this...
third party image
Well... minus the brown goop. Tht was the old oil that had turned to varnish.
Good Luck,
Aaron
frank thomas
04-08-2007 11:09:10
 Re: steering box fluid on 165? in reply to Aaron Ford, 04-08-2007 10:56:38
Thank you the picture is gread. Ill bet cause there is no oil the bearings are gone and thats where the play is comming from
DavidP, South Wales
04-08-2007 12:37:46
 Re: steering box fluid on 165? in reply to frank thomas, 04-08-2007 11:09:10
Hi,
When you adjust the box, find the 'high spot' in the straight ahead position. Adjust so that the steering just passes smoothly over this.
DavidP
kenojoe
04-10-2007 13:06:57
 Re: steering box fluid on 165? in reply to DavidP, South Wales, 04-08-2007 12:37:46
Could you explain how to make that adjustment a little bit more. Thanks for any help.
