Auxillary Hydraulics MF 165
Toby 165
04-07-2007 13:38:54
I just put my tractor back together after replacing the shift fork and pulling the top cover off the hydraulics and cleaning everything out real good. The Hydraulics were not working at all before. I am getting pressure now. It has a 2 spool valve for the front loader. The front bucket will tilt and the arms will raise by using the 2 spool valve. When using the auxillary valve to raise the front bucket the 3 point also raises. The front bucket will only raise to a point where the 3 point is at its maximum lift. Any advice would be greatly appreciated. I have the operators manual and believe I have everything set right.
Thank you
Toby
lonestarjeff
04-07-2007 19:44:14
 Re: Auxillary Hydraulics MF 165 in reply to Toby 165, 04-07-2007 13:38:54
Toby...is your 2-spool loader valve mounted on the lift cover under the seat? If so, you have to "lock out" the rear lift to use the loader. There should be a screw or knob on the valve to divert pressure to the loader.
Jeff
