Clutch Problems
Zach Straatmann
04-05-2007 18:58:01
I have a problem with a clutch on our 245 Massey Ferguson. I can't get it out of reverse. It is stuck in the reverse position but the shifter is is in neutral. I can change it from high to low. I can turn it on and drive only in reverse. How do i get it out of the reverse gear? I think the pin is stuck, but i am not for sure. Any help would be greatly appreciated. Thanks
Big Dean
04-06-2007 04:07:41
 Re: Clutch Problems in reply to Zach Straatmann, 04-05-2007 18:58:01
This is from my web sire Getting the main shift lever unstuck Pull your filler plug for the transmission look inside you will see a big gear. Find a level spot shut off the tractor. Push the clutch down & put the high low shifter in neutral to relieve any pressure that might be on the gears. With a long screwdriver or a small pry bar pry the big gear forward if it is hung in reverse. Pry it back if it is hung in first gear. If you happen to go to far it will go in the other gear. You need to get it in the center. You should be able to feel the detent balls pop in the grooves in the shift rail as you move the gear. Through the years I have probably unstuck at least a 1000 of them this way. It is a common problem on the Massey tractors after they get a little wear on them
