35 - oil on brakes
croitear
04-05-2007 06:50:00
If oil is leaking into the drums from the axles - what seals would need replacing, and is this a big job. Thanks
DavidP, South Wales
04-05-2007 11:48:32
 Re: 35 - oil on brakes in reply to croitear, 04-05-2007 06:50:00
Hi,
The job in itself is straightforward..... but;
The hub is held onto the axle shaft with a collar which has to de drilled to remove it and heated to fit it. Once the collar is off you will need a special puller and/or press to remove the hub. They have been known to come off by dropping the end of the axle shaft down on a large steel block, but it does not happen very often. Changing the seal in the hub is simple as is the one in the axle housing. Unless you have the equipment I would suggest taking it to your local MF repairer.
Cheers
DavidP,South Wales
