MF 135 Diesel Oil Pressure
Joe Dunn
04-01-2007 10:17:48
My 135 3 cyl. diesel when first cranked shows approximately 1/2 guage oil pressure. After operating for an hour or two the pressure gradually drops to just above zero on guage. The tractor does not noticeably lose power, does not smoke like burning oil, and runs smooth as silk. What could be causing this?
Dean
04-01-2007 19:28:49
 Re: MF 135 Diesel Oil Pressure in reply to Joe Dunn, 04-01-2007 10:17:48
Joe:
This can be caused by several things but most likely it is due to excessive clearence in the oil pump and/or engine bearings.
What weight oil are you using?
Try changing to straight 40W (not 15W40) diesel spec oil. Yes, I know it is hard to find.
If your hot oil pressure increases with straight 40W oil, your engine has exessive clearences somewhere.
By the way, does your engine have a spin on oil filter or a canister type filter?
Post back and I will explain why I asked.
Dean
135 Fan
04-01-2007 10:46:06
I would put a good gauge right on the block and make sure you are getting enough oil pressure. Your gauge could be shot or maybe your oil pump is getting tired. Oil pressure will drop a little when the engine is hotter. Dave
