oil pressure switch on mf 135
knjj
04-01-2007 06:14:09
what purpose does the oil pressure switch serve on a mf 135 with a perkins 3 cylinder diesel engine? will the motor start if the oil pressure switch is bad? thanks.
Big Dean
04-01-2007 07:16:14
 Re: oil pressure switch on mf 135 in reply to knjj, 04-01-2007 06:14:09
That oil pressure switch is what excite the regulator if you have an alternator which in turn excites the alternator and the fuel gauge. If you have a generator it excites the fuel gauge only.
135 Fan
04-01-2007 09:44:45
 Re: oil pressure switch on mf 135 in reply to Big Dean, 04-01-2007 07:16:14
Is it the same on a UK model? I'm pretty sure my oil pressure gauge is mechanical and not electric. On my Cat there is a pressure switch for oil pressure but all it does is power the hour meter. Oil pressure is with a mechanical gauge. Dave
MF Poor
04-01-2007 14:24:35
 Re: oil pressure switch on mf 135 in reply to 135 Fan, 04-01-2007 09:44:45
The pressure switch is used with a "mechanical" gauge. It senses oil pressure then completes curcuit to excite alternator and fuel gauge. It's mounted directly below the gauge. tee-ed into oil pres. gauge line. Not talking about a sending unit.
