seized engine on my tef20 any thoughts
Dave O'Connor
03-30-2007 06:30:51
hey i'm wondering can you help my i have started restoring my grandads old tef20 but i have found the engine seems to have seized,it hasn't started or moved in over 10 years, the starter is fine and there was plenty oil in it for the ten years(ity has been changed though)i have taken of the injectors and sprayed some diesal and penatrating oil into the engine and left it for a while but no luck. i have tried turning it with the crank handle but it wont move a bit,can anybody help me get this engine back moving again, cheers,
dave
traper
03-31-2007 17:01:41
 Re: seized engine on my tef20 any thoughts in reply to Dave O'Connor, 03-30-2007 06:30:51
Dave//pull starter put small flat bar or big screwdriver on teeth and pry both ways.I have a 135 d had water down open stack when i got it.Pulled inj.sucked out water with vaccum pump added ATF sat a week it came loose.
mike a. tenn.
03-30-2007 20:12:15
hey dave!...i see you made it to the MASSEY ferguson forum. lots of good guys on here too. you still haven't quite made it to the HARRY ferguson forum (one step down from here) your TE-20 is a "ferguson" tractor, not a "massey" ferguson. the ferguson forum is dedicated to the TO, TE and TEA, fergusons, like yours.
if you want to, email me... mikeamalong-at-centurytel-dot-net. (remove all the dashes and use @ and .) i think i might be able to help you out.
-mike
Dale L
03-30-2007 19:29:59
Dave I have run into that problem a few time's. Don't make the same mistake I made. Make sure the valves are loose before you turn over the engine or you will end up with bent push rods,broken springs or worse.Good luck
supergrumpy
03-30-2007 12:41:59
previous owner of my MF135 got the tractor when he bot the farmland, engine was rusted up tight, they towed it until engine broke loose and mowed with it until oil smoke got too bad
local mechanic tore it down and showed him the broken piston lands and rings, he rebuilt the engine and did a real good job, then the guys wife left him and he wanted to sell the tractor, I basically got it for cost of the rebuild, good running machine
so take your time, search the archives here and on main tractor page for how others have done it, filling cylinders with trans fluid and letting her sit a long time that way is how I would do it
RANDY GROVER
03-30-2007 08:25:49
I AM A SHOP TEACHER IN A HIGHSCHOOL IN IDAHO, WE HAVE HAD GOOD LUCK LUBING UP THE CYLINDERS, PUT THE TRACTOR IN GEAR AND ROCK IT BACK AND FORTH MORNING AND NIGHT, SOMETIMES THAT MUCH JAR WILL LOOSEN UP THE CYLINDERS--GOOD LUCK- NEXT STEP TAKE HEAD OFF AND GO FROM THERE.
