1150 hydraulics
david austin
03-29-2007 08:56:09
went through the motions with pressure and flow guages yesterday and ended up back at charge pump where we only have 2 gpm removed pump and checked it over with mechanic with 35 yrs experience in tractors didnt see anything obvious what next rebuild charge pump? new one is 1400.00 ?????
holm1155
03-31-2007 06:28:17
 Re: 1150 hydraulics in reply to david austin, 03-29-2007 08:56:09
The dump valve is in the cover that the charge pump is fastened to.There should be a pin that sticks up through the floor plate between your feet with a ring on top.You can pull up on the ring when you are going to start the tractor so the starter is not working against hyd pressure.There is a snap ring on the pin that can wear or the pin can wear allowing the valve to slip down dumping the oil back into the rearend.
holm1155
03-31-2007 18:50:52
 Re: 1150 hydraulics in reply to holm1155, 03-31-2007 06:28:17
The pieces you are describing are the cover & hold down clip for the dump valve. The snap ring may have worn or broke allowing the valve to drop down. When you take the pump off, check to see if it dropped down. It will be in one of the holes that the orings seal against.
david austin
04-01-2007 06:04:12
 Re: 1150 hydraulics in reply to holm1155, 03-31-2007 18:50:52
o.k. pumps on bench thatvalve will move up and down freely but i can remove it without any tools when i took off charge pump cover i could see the end of the valve it was up against the cover all the way? no o rings against pickup just flat type rubber washer .
holm1155
04-01-2007 21:32:11
 Re: 1150 hydraulics in reply to david austin, 04-01-2007 06:04:12
There should be a snap ring groove in the stem of the valve, and at the top there should be a hole for a ring.On the top side of the cover there should be a special washer that the snap ring should sit in when the vavle is down.[Pump position.]To send oil back to sump to aid the starting of the tractor you would pull up on the ring which would be just above the platform between your feet. When the tractor starts you can push the valve down for the oil to go to the radial pump up front.If the snap ring,which looks like piece of wire,does not stay in it's groove,the valve will drop down to far and open up to sump. You may have to replace the vavle,snap ring &washer to fix it.
david austin
04-02-2007 05:30:27
 Re: 1150 hydraulics in reply to holm1155, 04-01-2007 21:32:11
YAHOO !!!! removed valve drilled and installed cotter pin reassembled with new o rings WORKS GREAT STEER WITH ONE FINGER thanks so much Dave
holm1155
04-03-2007 06:06:09
 Re: 1150 hydraulics in reply to david austin, 04-02-2007 05:30:27
Dave, Glad to here you got it working.Always a relief when you get them repaired and don't have to put a lot of money into them. Harlan PS: You had asked for phone # 815-631-7322
david austin
04-01-2007 14:21:02
please respond im at a shut dsown and desperaTE RIGHT NOW FOR THE FIX and Thanx so much phone # please for appreciacion sdpelling wrong im sure Dave
david austin
03-31-2007 14:37:32
the floor is out and im looking at this cover there is no ring there is a metal cap about the size of a silver dollar that is convex shaped with a hole in the center with a c shaped retainer around it ????? ? when we had the cover off there is nothing on the other side of this????? im going to change o rings tomorrow Am ?? thanks again
holm1155
03-30-2007 07:44:49
Check your dump valve to make sure it is closeing properly. Also check the seal under the pump. [between the pump & suction tube]I have also seen the key under the rotor in the pump wear out so the rotor will not turn. Good luck. Question for barnrat, Where can you get the charge pump for $850. I have not found them for less than $1200.
barnrat
03-31-2007 07:01:46
 Re: 1150 hydraulics in reply to holm1155, 03-30-2007 07:44:49
I buy a lot of parts and work on a lot of Masseys. Mabie brothers in Kirkville NY gets most of my Massey parts business. I cant remember what they wanted for the pump but it was considerbly less then $1200. The $850 pump is available from Wengers of Meyerstown PA.
david austin
03-30-2007 09:38:31
where is the dump valve and how do i check it it looked like maybe a little bit of rust around the seat for the combining valve when i took it out it came out dry cleaned with very fine cloth and thanks again to all for suggestions Dave
barnrat
03-29-2007 10:41:51
First off new charge pump is $850 and no rebuild to it. Second before you go spend that kind of money check the condition of the O rings on top of the pump they can fail if the filter plugs. Also was the 2 gpm the combined volume of both pumps or what you got at each pump?
david austin
03-30-2007 06:05:34
 Re: 1150 hydraulics in reply to barnrat, 03-29-2007 10:41:51
i got 2 prices on the pump one was 1400 other was 1650 but regardless im in maine 2 gpm at combined charge pump supply tube. o rings were fairly flat but looked good should i try changing them thanks Dave
barnrat
03-30-2007 06:59:54
 Re: 1150 hydraulics in reply to david austin, 03-30-2007 06:05:34
Id try the O rings first. 2gpm seems low even for a whipped pump. I think there may be more there then meets the eye. Good luck, double and triple check everything before you blow the money on that pump.
