MASSEY FERGUSON TO-35 TRACTOR
DERRELL DANIEL
09-14-2000 04:59:40
MY QUESTION IS ABOUT THE TO-35 4 CYL.DIESEL ENG.HOW CAN I TELL IF IT IS A PERKINS ENG. OR A 4 CYL STANDERED DIESEL ENGINE.AND WILL ANY OF THE PARTS INTERCHANGE WITH EACH OTHER? ON MY TRACTOR THE INJECTORS AND THE PUMP ARE ON THE LEFT SIDE OF THE ENGINE IF YOU WERE DRIVING THE TRACTOR.THANK YOU IN ADVANCE.
matt j
09-16-2000 12:26:51
 Re: MASSEY FERGUSON TO-35 TRACTOR in reply to DERRELL DANIEL, 09-14-2000 04:59:40
if it's a 4 cyl. then it's a standard 23c. built in england. my to-35 is 1958 am in the middle of rebuilt. some parts hard to find and cost alittle more than others. have alot of info and contacts if you want info send me a message
Jack in NB
09-16-2000 02:55:36
Derrell -
The 4 cyl is most likely a Standard - model 23C.
Exhaust on the right side (from the seat). Perkins exhausts are on the left side. Fuel pump on the back left of the block. Perkins on the right. Serial number on the top right front of the block, above the gen/alt. SJ######.
Strong smooth engine - ours had over 5000 hours, crank was still standard size. Hard starting, cured by a block heater or a 200 watt heater in the lower rad hose. Even in the summer!!!!! Once it starts, it's good for the day.
Parts are not interchangeable with the Perkins, although the rest of the tractors are the same. Reasonable prices, good stocks here in Canada.
You have a good tractor, once you get the 40 year accumulation of snags cleaned up!
DERRELL DANIEL
09-21-2000 05:55:52
 Re: Re: MASSEY FERGUSON TO-35 TRACTOR in reply to Jack in NB, 09-16-2000 02:55:36
HELLO JACK IN NB.WILL YOU CALL ME AT 912-474-7447 OR SEND ME YOUR E-MAIL ADDRESS I WOULD LIKE TO TALK TO YOU ABOUT FINDING PARTS FOR MY TO-35 THANK YOU IN ADVANCE DERRELL.
Charles Jackson
09-14-2000 09:57:44
I have a 4-cyl Diesel 35 MF. I thought all 4 cyl
were Standard Engine and the 3 Cyl. were Perkins.
My Standard cost a bundle to rebuild. I think
they were tough tractors. A common problem is hard starting.
pierce fallon
09-15-2000 11:37:03
 Re: Re: MASSEY FERGUSON TO-35 TRACTOR in reply to Charles Jackson, 09-14-2000 09:57:44
well I had a 35x and it had a three cylinder perkins all three cyl were perkins .it is a 152 AD3
If you look at the breather pipe going into the side of the head block there should be some indication as to what engine it but my opinion would be that it is a standard. pierce
