Diesel Fuel System
Larry Thompson
09-14-2000 00:38:18
I have a 135 MF and have lost my manuel. Could anyone refresh me on how to bleed the system when changing filters, Etc.
Thanks
Larry Thompson
Jack in NB
09-15-2000 09:41:04
 Re: Diesel Fuel System in reply to Larry Thompson, 09-14-2000 00:38:18
Hi Larry -
The book says bleed, in order, the primary filter, secondary filter (if fitted) the top bleed screw and then lower bleed screw on the injector pump. This follows the fuel flow from the fuel pump to the "action center" in the injector pump.
Bleed each until clear fuel flows, then close.
Then a few extra pump strokes to get fuel flowing from the injector pump overflow.
We've had some success just bleeding the two easier-to-access screws on the injector pump.
Hope this helps.
