no reverse gear MF40, need help
steve downes
03-26-2007 14:23:52
looking for help. I have an MF40 loader/backhoe that has a semi auto gear box (ie a forward and reverse pedal and 1st and 2nd gear with high and low). i have a problem in that it will not select reverse.
any ideas on whats wrong and how to fix?
mn.Chuck
03-26-2007 15:04:25
 Re: no reverse gear MF40, need help in reply to steve downes, 03-26-2007 14:23:52
Steve, One easy possibility-hoping. As former MF
dealers we occassionaly had a unit come in for
work and the problem was the small rockshaft actuated by the pedal thru a stiff spring. The
rockshaft has no routine way to lube and it would
become too tight for the spring to actuate. With
some WD 40 or ? and a visegrip, rotate that small
shaft back and forth a bit and work some lube in.
Worth a try. Chuck
